[GRASS5] Debian and d.m/d.zoom bug - /etc/ld.so.conf
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Dec 1 08:18:59 EST 2004
On Wed, 1 Dec 2004, Markus Neteler wrote:
> d.m is now updated in CVS.
> Debian users: please try again (don't forget to revert the /etc/ld.so.conf change
> for testing, run ldconfig as well).
> I had to modify lib/init/grass-run.sh to make it working for Fedora:
> LD_LIBRARY_PATH=$LD_LIBRARY_PATH:"$GISBASE/lib"
> ^^^^^^^^^^^^^^^^^-added
> Hopefully this problem is resolved now.
Well in general it looks like it should just be passing on the current
LD_LIBRARY_PATH (whatever that contains). Would something like
exec xterm -e LD_LIBRARY_PATH=$env(LD_LIBRARY_PATH) d.zoom
(in the Tcl code) not work?
And there is also the problem (noted in Glynn's original e-mail) that e.g.
LD_LIBRARY_PATH is called different things on different platforms, e.g.
DYLD_LIBRARY_PATH on OS X. But this can be fixed by dynamically
substituting the correct variable name in at compile-time like is done for
lib/init/init.sh
Paul
