[GRASS5] Debian and d.m/d.zoom bug - /etc/ld.so.conf
Glynn Clements
glynn at gclements.plus.com
Thu Dec 2 05:33:31 EST 2004
Markus Neteler wrote:
> > And there is also the problem (noted in Glynn's original e-mail) that e.g.
> > LD_LIBRARY_PATH is called different things on different platforms, e.g.
> > DYLD_LIBRARY_PATH on OS X. But this can be fixed by dynamically
> > substituting the correct variable name in at compile-time like is done for
> > lib/init/init.sh
> [isn't it easier to handle such necessary conditions in grass-run.sh
> rather than messing up d.m.tcl? ]
Yes. The LD_LIBRARY_PATH_VAR substitution should be performed on
grass-run.sh.
