[GRASS5] Debian and d.m/d.zoom bug - /etc/ld.so.conf
Glynn Clements
glynn at gclements.plus.com
Sat Dec 4 15:21:56 EST 2004
Paul Kelly wrote:
> >> I was thinking if we
> >> need to pass on an already existing LD_LIBRARY_PATH, it needs to be
> >> evaluated before xterm is run as that is what unsets it.
> > Yes. One option would be to copy it to a separate variable, e.g.:
> > set env(saved_lib_path) $env(LD_LIBRARY_PATH)
> > exec xterm -e ...
> > and have grass-run.sh restore it from that. Although that requires the
> > Tcl/Tk code to know about the platform-specific variable names.
> > Another option would be to dump the entire environment to a file and
> > have grass-run.sh restore it.
> Well as I understand it everything else will be preserved: it is just
> LD_LIBRARY_PATH that is unset; is that right?
There are a couple of other LD_* variables which are unset, e.g.
LD_PRELOAD.
> What about just setting another variable in Init.sh? After the correct
> LD_LIBRARY_PATH for the GRASS session has been determined and set,
> copy it also to GRASS_LD_LIBRARY_PATH. That wouldn't be unset by xterm and
> then it could be restored to LD_LIBRARY_PATH in the script.
Agreed. Although this doesn't entirely solve the issue of
platform-specific variable names, it removes it from the Tcl/Tk code.
> Although I
> suppose if the user changed their LD_LIBRARY_PATH after starting the GRASS
> session something might be missing, but that would probably be quite unlikely.
We don't need to support that. The user can always change
GRASS_LD_LIBRARY_PATH if they really need to.
