[GRASS5] NVIZ updates
Bob Covill
bcovill at tekmap.ns.ca
Mon Dec 6 07:16:18 EST 2004
Helena,
Helena wrote:
> I have added 2 modfications from Tomas to nviz volume support:
> 1. Default polygon resolution for drawing isosurfaces is now a smaller
> number
> (higher resolution) to avoid situation when nothing is drawn.
> 2. Load state/Save state was added for volume objects.
> Bob, after the nviz startup has changed, Load state/Save state does not
> work
> - it gives an Error: can't read env(GISDBASE)
> Can this be fixed before the release or should I file a bug report?
I will grab the above updates today and look into fixing the above
problem. My guess is that it should not be too difficult to fix. I will
let you know.
> Let me know if there are any problems with the new additions,
> Helena
Bob
