[GRASS5] NVIZ updates
Bob Covill
bcovill at tekmap.ns.ca
Mon Dec 6 10:02:59 EST 2004
Helena,
I have applied a couple of nviz fixes to CVS.
I could not re-produce the GISDBASE error, but it was being generated
from the fileBrowser.tcl script. It was looking from an "images"
directory in your mapset. It is probably a throw-back to an earlier
version for saving screen-captures to an "images" directory in your
mapset. I have removed reference to GISDBASE and the the fileBrowser
simply starts in your current directory (pwd).
I also fixed an error in attIsosurfPopup.tcl which complained about an
unknown reference to DEBUG.
Everything else seems to be working fine.
Bob
Helena wrote:
> I have added 2 modfications from Tomas to nviz volume support:
> 1. Default polygon resolution for drawing isosurfaces is now a smaller
> number
> (higher resolution) to avoid situation when nothing is drawn.
> 2. Load state/Save state was added for volume objects.
> Bob, after the nviz startup has changed, Load state/Save state does not
> work
> - it gives an Error: can't read env(GISDBASE)
> Can this be fixed before the release or should I file a bug report?
> Let me know if there are any problems with the new additions,
> Helena
