[GRASS5] FW: [winGRASS] libgrass_gis.dll was not found !
Andrea Antonello
moovida at katamail.com
Mon Dec 6 10:07:55 EST 2004
Hy Koukoulas Sotiris,
I have a question, to be sure I understand the issue.
If it is on windows, shouldn't it run under cygwin and use *.so shared
libraries instead of *.dll? Since when are the shared libs compiled native on
windows?
Anyway, does the file libgrass_gis.dll exist on your system?
Best regards,
Andrea
On Monday 06 December 2004 15:50, Koukoulas Sotiris wrote:
> ________________________________
> From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]
> On Behalf Of Koukoulas Sotiris
> Sent: Monday, December 06, 2004 2:28 AM
> To: wingrass at grass.itc.it
> Subject: [winGRASS] libgrass_gis.dll was not found !
> Dear all,
> I have recently installed Grass 5.7 for Windows and I get an error
> message as the Display Manager starts:
> <ps.map - Unable to locate component
> This application has failed to start because libgrass_gis.dll was not
> found. Re-installing the application may fix this problem.>
> In the xterm I get the following:
> GRASS 5.7.0:~ > Error in startup script: child process exited abnormally
> while executing
> "exec ps.map -p" (procedure "DmPrint::init" line 14) invoked
> from within
> "DmPrint::init" (procedure "main" line 27) invoked from within
> "main $argc $argv"
> (file
> "/usr/local/grass5.7.0-i686-pc-cygwin-24_06_2004/etc/dm/d.m.tcl" line
> 773)
> How can I resolve this?
> Many thanks in advance,
> Sotirios Koukoulas
____________________________________________________________________________
HydroloGIS - Environmental Open Source Solutions
www.hydrologis.com
Andrea Antonello
Environmental Engineer
mobile: +393288497722
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
