[GRASS5] FW: [winGRASS] libgrass_gis.dll was not found !
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Dec 6 10:21:17 EST 2004
On Mon, 6 Dec 2004, Andrea Antonello wrote:
> Hy Koukoulas Sotiris,
> I have a question, to be sure I understand the issue.
> If it is on windows, shouldn't it run under cygwin and use *.so shared
> libraries instead of *.dll? Since when are the shared libs compiled native on
> windows?
Cygwin shared libraries are always .dll (well any I have ever seen and
certainly the GRASS ones).
> Anyway, does the file libgrass_gis.dll exist on your system?
Perhaps the PATH variable has come unset similar to the recent problems on
Debian (why the grass-run.sh script was introduced). Perhaps changing d.m
to launch ps.map using grass-run.sh would fix the problem (PATH is the
equivalent of LD_LIBRARY_PATH on Cygwin)
Paul
