[GRASS5] FW: [winGRASS] libgrass_gis.dll was not found !
Andrea Antonello
moovida at katamail.com
Mon Dec 6 11:26:58 EST 2004
> Cygwin shared libraries are always .dll (well any I have ever seen and
> certainly the GRASS ones).
Thanks Paul! Hmm, my ignorance. So the next question (so that I can see the
light at some point): Can I use that dll to call it's functions outside of
the Cygwin environment? Let's say I want to call some function from inside a
java environment. Obviously supplying the needed grass environment. Is that
enough?
> Thanks for your replies. File libgrass_gis.dll does not exist in my
> system... Where can I find it?(if it is the only one that I am
> missing...)
Dear Sotiris, I'm sorry, but I have no idea. I was thinking it was some
missplaced path, but you really miss the library.
Guess Paul will tell us the solution.
Best regards,
Andrea
____________________________________________________________________________
HydroloGIS - Environmental Open Source Solutions
www.hydrologis.com
Andrea Antonello
Environmental Engineer
mobile: +393288497722
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
