[GRASS5] FW: [winGRASS] libgrass_gis.dll was not found !
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Dec 6 11:30:27 EST 2004
On Mon, 6 Dec 2004, Andrea Antonello wrote:
>> Cygwin shared libraries are always .dll (well any I have ever seen and
>> certainly the GRASS ones).
> Thanks Paul! Hmm, my ignorance. So the next question (so that I can see the
> light at some point): Can I use that dll to call it's functions outside of
> the Cygwin environment? Let's say I want to call some function from inside a
> java environment. Obviously supplying the needed grass environment. Is that
> enough?
Possibly. I think you need the Cygwin dll as well. But yes it might work!
>> Thanks for your replies. File libgrass_gis.dll does not exist in my
>> system... Where can I find it?(if it is the only one that I am
>> missing...)
> Dear Sotiris, I'm sorry, but I have no idea. I was thinking it was some
> missplaced path, but you really miss the library.
> Guess Paul will tell us the solution.
It seems it was a binary distribution compiled with static libraries. So
I've no idea where the request for the dll came from.
Paul
