FW: [GRASS5] FW: [winGRASS] libgrass_gis.dll was not found !
Koukoulas Sotiris skouk at geo.aegean.gr
Mon Dec 6 10:34:17 EST 2004
-----Original Message-----
Sent: Monday, December 06, 2004 5:33 PM
To: 'Paul Kelly'
Subject: RE: [GRASS5] FW: [winGRASS] libgrass_gis.dll was not found !
Dear Paul and Andrea,
Thanks for your replies. File libgrass_gis.dll does not exist in my
system... Where can I find it?(if it is the only one that I am
missing...)
S.
From: Paul Kelly [mailto:paul-grass at stjohnspoint.co.uk]
Sent: Monday, December 06, 2004 5:21 PM
To: Andrea Antonello
Cc: grass5 at grass.itc.it; Koukoulas Sotiris
Subject: Re: [GRASS5] FW: [winGRASS] libgrass_gis.dll was not found !
On Mon, 6 Dec 2004, Andrea Antonello wrote:
> Hy Koukoulas Sotiris,
> I have a question, to be sure I understand the issue.
> If it is on windows, shouldn't it run under cygwin and use *.so shared
> libraries instead of *.dll? Since when are the shared libs compiled
native on
> windows?
Cygwin shared libraries are always .dll (well any I have ever seen and
certainly the GRASS ones).
> Anyway, does the file libgrass_gis.dll exist on your system?
Perhaps the PATH variable has come unset similar to the recent problems
on
Debian (why the grass-run.sh script was introduced). Perhaps changing
d.m
to launch ps.map using grass-run.sh would fix the problem (PATH is the
equivalent of LD_LIBRARY_PATH on Cygwin)
Paul
