[GRASS5] [bug #2820] (grass) v.build: discuss mysterious "support files"
Markus Neteler
neteler at itc.it
Thu Dec 9 11:37:11 EST 2004
On Thu, Dec 09, 2004 at 12:15:56AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2820
> In the v.build documentation, discuss these mysterious "support
> files". Perhaps they are the files that live in .../dbf/... . Perhaps
> they are the files called cidx coor dbln head hist sidx topo ... no it
> couldn't be them.
> Say just when one would need to use v.build. I mean who would want to
> go thru life without "support". And the more support, and the more
> often, the better.
Question: Why not reading more than the first line?
Citation:
http://grass.itc.it/grass57/manuals/html57_user/v.build.html
"DESCRIPTION
These support files supply topology and category information
that are needed by other GRASS programs
> Show how one can determine if one doesn't have support, but should,
> and if one has support, but it isn't needed, etc.
I have added now:
"GRASS is generating these support files automatically,
only in rare cases the user has to (re)build them.
No, I won't explain "rare cases" in the documentation.
A rare case occurs if e.g. Radim asks the user to run v.build to
rebuild the topology for existing 5.7 maps in case of a format
change. Happened a very few times in the past.
> Also,
> Parameters:
> error Name of vector where errors are written
> Say what will happen if we don't give this. Do our errors go up in
> smoke...etc? Will we still be informed of them? Say so.
Yes, Sir.
Changed the message to:
- err_opt->description = "Name of vector where errors are written";
+ err_opt->description = "Name of vector map where erroneous vectors are written to";
and added
+In case of errors, the user can optionally generate an error
+vector map containing the erroneous vectors for later inspection.
to the documentation.
> don't say "write topology to stdout"
> say "build topology, but only write it to stdout, not the files"
Why? This is not the case.
> or "don't build topology, instead only write any topology already
> found to stdout..."
Even not the case.
Markus
