[GRASS5] OVERWRITE
Radim Blazek
blazek at itc.it
Thu Dec 9 12:01:07 EST 2004
Glynn Clements wrote:
> We could have a dedicated flag, e.g. --overwrite (including
> abbreviations, e.g. --o). Although that would require scanning the
> argument list twice, unless it was required to come first.
Done, added also 'overwrite' to GModule which is used by g.copy/rename.
'-o' removed from g.copy/rename, r.composite.
Maps can be overwritten either using --overwrite/--o or OVERWRITE grass
variable can be set to 1 (g.gisenv set=OVERWRITE=1).
Radim
