[GRASS5] d.m: nviz start bug
Markus Neteler
neteler at itc.it
Fri Dec 10 11:42:50 EST 2004
On Fri, Dec 10, 2004 at 09:36:59AM -0700, Michael Barton wrote:
> At the moment, I've just put a warning label on my download site about this,
> saying you must run r3.createwind.
Mhh, but it's not needed any longer to run g3.createwind.
> I thought this was in the process of being fixed (already fixed??) so that
> nviz would generate a 3d region file (or parameters in the merged WIND/WIND3
> file) if it found them missing. So I thought that it was a non-issue that
> would go away on its own soon. Am I overly optimistic?
Yes, nviz generates a 3d region file if it found them missing.
The problem is that nviz in d.m seems to be started in a different
way. But I don't understand how/why.
It *should* work out of the box.
Markus
> On 12/10/04 7:50 AM, "Markus Neteler" <neteler at itc.it> wrote:
> > Hi,
> > a question concerning d.m:
> > While launching
> > nviz el=elevation.dem
> > from CMD line works well, the lauch of
> > NVIZ from the d.m menu fails if the WIND3 file
> > was not generated yet:
> > It seems that the tcl part cannot handle
> > nviz
> > WARNING: G3d_readWindow: unable to find
> > [/ssi0/ssi/neteler/grassdata/spearfish57/user1/WIND3].
> > Creating WIND3 File
> > My assumption is the G_warning message disturbs the tcl part.
> > Any ideas?
> > Markus
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human, Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
