[GRASS5] Re: Vector symbols & g.region
Sun Dec 12 04:46:13 EST 2004
Michael Barton wrote:
> I'm not sure if this helps or not, but issuing a find command that is
> redirected to a text file or variable could create such a list that could
> then be grep'ed to get the part of the path name needed by a simple loop in
> d.vect and vector.tcl.
> E.g:
>  find -f $GISBASE/etc/symbol/ > symbolpath
Don't use "find". For a start, it might not be installed on Cygwin (or
the native find.exe might come first in the path); I don't know about
OSX.
Writing directory scanning code isn't particularly complex. In C, the
basic logic is essentially:
#include <sys/types.h>
#include <sys/stat.h>
#include <unistd.h>
#include <dirent.h>
void scan_directory(const char *directory)
	DIR *dir = opendir(directory);
	if (!dir)
		return;
	for (;;)
		char path[PATH_MAX];
		struct stat st;
		struct dirent *d;
		/* get next directory entry */
		d = readdir(dir);
		if (!d)
			break;
		/* skip hidden files/directories */
		if (d->d_name[0] == '.')
			continue;
		/* convert filename to absolute path */
		sprintf(path, "%s/%s", directory, d->d_name);
		/* get type (file/dir/symlink/etc) */
		if (lstat(path, &st) < 0)
			continue;
		if (S_ISDIR(st.st_mode))
			/* recurse into subdirectory */
			scan_directory(path);
		else if (S_ISREG(st.st_mode))
			/* process regular file */
			do_something_with_file(path);
	closedir(dir);
