[GRASS5] migration from 5.3 to 5.7
Helena
hmitaso at unity.ncsu.edu
Sun Dec 12 21:50:38 EST 2004
Moritz Lennert wrote:
> On Sun, December 12, 2004 3:57, Helena said:
>>Also, it would be extremely useful to have a table that will show which
>>commands
>>were replaced by which, e.g.
>> 5.* 6.0 comments
>>g.projinfo g.proj -p merge of g.setproj and g.projinfo
>>s.surf.rst v.surf.rst merge of s.surf.rst and v.surf.rst, works now
>>both for contours and point data
> Have you looked at this:
> http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/v.modules.html
> And there is also:
> http://grass.gdf-hannover.de/twiki/pub/GRASS/GrassToDoList/54to57porting_11-2004.txt
> Both might be a base for what you are looking for...
> Moritz
Thank you all for the feedback - I have seen the above files some time ago but I have completely
forgotten about them - that is almost done what I had in mind, it just needs to be updated
and linked to the proper places (GrassSixTutorial?)
Markus, you may add a hint to 5.* users migrating to 5.7 to add pts or site suffix
to the names of their site files - actually it may be useful to add it in v.in.sites.all
because people may have sites and vector files with the same names (as I do)
and if v.in.sites.all and v.in.convert.all are both run the files will be overwritten.
Helena
