[GRASS5] nviz vector points display
Markus Neteler
neteler at itc.it
Mon Dec 13 04:20:01 EST 2004
On Sun, Dec 12, 2004 at 09:34:59PM -0500, Helena wrote:
> And finally - we just got rid of all the messages produced by nviz
> (thanks to Bob) to make sure that user does not miss any warnings given at
> the start
> of the program but now
> GRASS_INFO_PERCENT: xx writes each new % on new line, so the user sees just
> endless
> lines of this - can the message be written on the same line as before?
> This is causing problems in v.surf.rst too.
I assume that
g.gisenv set=GRASS_MESSAGE_FORMAT=gui
will toggle the message format.
I have recently modified the init script to set GRASS_MESSAGE_FORMAT
according to user selection of working in text or GUI mode.
Not sure if it works correctly (but I think so).
GRASS_MESSAGE_FORMAT is documented at:
g.manual variables &
Hope this helps
Markus
