[GRASS5] r.plane and float
ivan marchesini
marchesini at unipg.it
Tue Dec 14 09:10:09 EST 2004
hi to all...
r.plane works really well... also using floating point value for
coordinates of the point the plain have to pass through....
the problem is if you have to realize a plane not very dip....
like 0.002... for example....
r.plain accept only integer value for dip values and instead I need to
use float values.....
have someone some ideas about how to solve this prloblem???
thank you very much
ivan
ivan marchesini <marchesini at unipg.it>
