[GRASS5] r.plane and float
Markus Neteler
neteler at itc.it
Tue Dec 14 17:58:38 EST 2004
On Tue, Dec 14, 2004 at 03:10:09PM +0100, ivan marchesini wrote:
> hi to all...
> r.plane works really well... also using floating point value for
> coordinates of the point the plain have to pass through....
> the problem is if you have to realize a plane not very dip....
> like 0.002... for example....
> r.plain accept only integer value for dip values and instead I need to
> use float values.....
> have someone some ideas about how to solve this prloblem???
Ivan,
finally I understood the problem.
Fixed in CVS.
but:
r.plane dip=0.003 az=33 ea=609000 no=4920855.000000 el=59 name=dd
609000
4920855.000000
Running r.in.ascii, please stand by
r.in.ascii: ** errors detected in header section **
Illegal row3 value
There is an updated needed in r.in.ascii (other modules?) due to
the recent WIND3 change.
Markus
