[GRASS5] nviz vector points display
Tue Dec 14 08:19:01 EST 2004
Markus Neteler wrote:
> > >How to avoid this output of GRASS_INFO_PERCENT: xx?
> > I am not sure where it comes from, is GRASS_INFO_PERCENT se to
> > something? From shell or d.m? If not, it could be bug in G_percent.
> It happens in d.m.
Currently, lib/gis/gui.tcl executes:
	set env(GRASS_MESSAGE_FORMAT) gui
at the top level.
It should be set for commands which are run via run_cmd (e.g. via
d.m's execute procedure) and unset for commands which are run through
the spawn, run and term procedures.
