[GRASS5] [bug #2852] (grass) Library - libgrass_interpfl.5.7.cvs.dylib
- is not built
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Dec 17 11:42:39 EST 2004
On Fri, 17 Dec 2004, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2852
> Subject: Library - libgrass_interpfl.5.7.cvs.dylib - is not built
> Platform: Mac OSX
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 57cvs_041217
> libgrass_interpfl.5.7.cvs.dylib is not built.
> Following this lib I have 2 missing bin: r.resamp.rst, v.surf.rst.
> Last rows in make:
> cc -dynamiclib -Wl,-flat_namespace,-U,_cuserid -compatibility_version 5.7 -current_version 5.7
You must have made some changes to your compile flags as those are
commented out in CVS
SHLIB_LD should be simply "cc -dynamiclib -single_module"
and any errors in individual modules should be corrected by fixing the
errors in the source code of that module, not by tweaking the global
compile flags.
