[GRASS5] error in lib/rst/interp_float
Kirk R. Wythers kwythers at umn.edu
Fri Dec 17 12:40:41 EST 2004
Anyone recognize this one:
truffula:~/grass5_dev/grass57_cvs/lib/rst/interp_float kirkw$ make
cc -dynamiclib -Wl,-flat_namespace,-U,_cuserid -compatibility_version
5.7 -current_version 5.7 -install_name
/usr/local/grass-5.7.cvs/lib/libgrass_interpfl.dylib -o
/Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/lib/
libgrass_interpfl.5.7.cvs.dylib -L/usr/X11R6/lib
-L/Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/
lib -L/usr/local/pgsql/lib   OBJ.powerpc-apple-darwin7.6.0/func2d.o
OBJ.powerpc-apple-darwin7.6.0/input2d.o
OBJ.powerpc-apple-darwin7.6.0/vinput2d.o
OBJ.powerpc-apple-darwin7.6.0/interp2d.o
OBJ.powerpc-apple-darwin7.6.0/output2d.o
OBJ.powerpc-apple-darwin7.6.0/point2d.o
OBJ.powerpc-apple-darwin7.6.0/secpar2d.o
OBJ.powerpc-apple-darwin7.6.0/segmen2d.o
OBJ.powerpc-apple-darwin7.6.0/write2d.o
OBJ.powerpc-apple-darwin7.6.0/matrix.o
OBJ.powerpc-apple-darwin7.6.0/minmax.o
OBJ.powerpc-apple-darwin7.6.0/init2d.o
OBJ.powerpc-apple-darwin7.6.0/ressegm2d.o
OBJ.powerpc-apple-darwin7.6.0/resout2d.o -lgrass_gis -lgrass_datetime
-lz    -lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree
-lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase  -L/usr/local/lib
-lgdal -lgeotiff -lgrass_bitmap -lgrass_qtree -lgrass_interpdata
-lgrass_dbmiclient -lgrass_dbmibase  -lgrass_gmath -lfftw    && ln -sf
ld: Undefined symbols:
_Cats2
_Map2
_Pnts
_count
_driver2
_ff
_sql2
/usr/bin/libtool: internal link edit command failed
make: ***
[/Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/
lib/libgrass_interpfl.5.7.cvs.dylib] Error 1
Thanks,
Kirk
