[GRASS5] error in lib/rst/interp_float
Huidae Cho grass4u at gmail.com
Sat Dec 18 04:48:05 EST 2004
It's fixed, so please test it after updating lib/rst and vector/v.*.rst
trees. All external symbols in the rst library (undefined at compile
time) has been moved to the library from each rst module.
Thank you.
Huidae Cho
On Fri, Dec 17, 2004 at 11:40:41AM -0600, Kirk R. Wythers wrote:
> Anyone recognize this one:
> truffula:~/grass5_dev/grass57_cvs/lib/rst/interp_float kirkw$ make
> cc -dynamiclib -Wl,-flat_namespace,-U,_cuserid -compatibility_version
> 5.7 -current_version 5.7 -install_name
> /usr/local/grass-5.7.cvs/lib/libgrass_interpfl.dylib -o
> /Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/lib/
> libgrass_interpfl.5.7.cvs.dylib -L/usr/X11R6/lib
> -L/Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/
> lib -L/usr/local/pgsql/lib   OBJ.powerpc-apple-darwin7.6.0/func2d.o
> OBJ.powerpc-apple-darwin7.6.0/input2d.o
> OBJ.powerpc-apple-darwin7.6.0/vinput2d.o
> OBJ.powerpc-apple-darwin7.6.0/interp2d.o
> OBJ.powerpc-apple-darwin7.6.0/output2d.o
> OBJ.powerpc-apple-darwin7.6.0/point2d.o
> OBJ.powerpc-apple-darwin7.6.0/secpar2d.o
> OBJ.powerpc-apple-darwin7.6.0/segmen2d.o
> OBJ.powerpc-apple-darwin7.6.0/write2d.o
> OBJ.powerpc-apple-darwin7.6.0/matrix.o
> OBJ.powerpc-apple-darwin7.6.0/minmax.o
> OBJ.powerpc-apple-darwin7.6.0/init2d.o
> OBJ.powerpc-apple-darwin7.6.0/ressegm2d.o
> OBJ.powerpc-apple-darwin7.6.0/resout2d.o -lgrass_gis -lgrass_datetime
> -lz    -lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree
> -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase  -L/usr/local/lib
> -lgdal -lgeotiff -lgrass_bitmap -lgrass_qtree -lgrass_interpdata
> -lgrass_dbmiclient -lgrass_dbmibase  -lgrass_gmath -lfftw    && ln -sf
> ld: Undefined symbols:
> _Cats2
> _Map2
> _Pnts
> _count
> _driver2
> _ff
> _sql2
> /usr/bin/libtool: internal link edit command failed
> make: ***
> [/Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/
> lib/libgrass_interpfl.5.7.cvs.dylib] Error 1
> Thanks,
> Kirk
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
