[GRASS5] nviz problem
Huidae Cho grass4u at gmail.com
Fri Dec 17 18:04:54 EST 2004
I noticed today that nviz doesn't work if I run it background as before.
Similarly, it just stops after displaying a map when it's executed from
"d.m &" which is recommended in the welcome message.
nviz elevation=dem &	# doesn't work
d.m &			# nviz doesn't work
nviz elevation=dem	# works!
d.m			# nviz works!
And I see nviz prints % prompt. Does anyone have a clue?
Thanks.
Huidae Cho
