[GRASS5] nviz problem
Helena
hmitaso at unity.ncsu.edu
Fri Dec 17 18:44:59 EST 2004
Huidae Cho wrote:
> Hi,
> I noticed today that nviz doesn't work if I run it background as before.
> Similarly, it just stops after displaying a map when it's executed from
> "d.m &" which is recommended in the welcome message.
> nviz elevation=dem & # doesn't work
> d.m & # nviz doesn't work
> nviz elevation=dem # works!
> d.m # nviz works!
> And I see nviz prints % prompt. Does anyone have a clue?
It must be the latest change that was done - I just tried it and it
does not work even if I do nviz elevation=dem, it displays the DEM
but fails to open the Main pannel and prints a % prompt.
It worked OK just a few days (weeks?) ago.
It may be related to the change in the startup script - Bob, are you
around? How does it work for you?
Helena
> Thanks.
> Huidae Cho
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
