[GRASS5] nviz problem
Bob Covill
bcovill at tekmap.ns.ca
Fri Dec 17 20:02:39 EST 2004
Hello,
I tried running the latest version of nviz in the background with
various options and it seems to work fine. The "%" prompt that you see
is perfectly normal. The nviz program is simply a customized version of
the Tcl/Tk "wish" executable. Try executing "wish" on the command line
and you should see the same prompt.
As for it crashing when it is run in the background, I have no idea. You
might try changing GRASS_MESSAGE_FORMAT environment variable to see if
that has any effect.
It might help to know what platform and Tcl/Tk version it is failing on.
For me it works on RedHat 7.3 with Tk8.3, and RedHat 9 with Tk8.4.
Bob
Helena wrote:
> Huidae Cho wrote:
>> Hi,
>> I noticed today that nviz doesn't work if I run it background as before.
>> Similarly, it just stops after displaying a map when it's executed from
>> "d.m &" which is recommended in the welcome message.
>> nviz elevation=dem & # doesn't work
>> d.m & # nviz doesn't work
>> nviz elevation=dem # works!
>> d.m # nviz works!
>> And I see nviz prints % prompt. Does anyone have a clue?
> It must be the latest change that was done - I just tried it and it
> does not work even if I do nviz elevation=dem, it displays the DEM
> but fails to open the Main pannel and prints a % prompt.
> It worked OK just a few days (weeks?) ago.
> It may be related to the change in the startup script - Bob, are you
> around? How does it work for you?
> Helena
>> Thanks.
>> Huidae Cho
>> grass5 mailing list
>> grass5 at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass5
