[GRASS5] nviz problem
Huidae Cho grass4u at gmail.com
Fri Dec 17 22:00:21 EST 2004
Now nviz is not a *wish script but a shell itself. That's why it prints
a prompt and we cannot execute it background and inside "d.m &". To fix
this problem, I think we should go back to NVWISH because running nviz
foreground is pain.
You can test this:
	wish &
prints % prompt and just stop!
Huidae Cho
On Fri, Dec 17, 2004 at 09:02:39PM -0400, Bob Covill wrote:
> Hello,
> I tried running the latest version of nviz in the background with
> various options and it seems to work fine. The "%" prompt that you see
> is perfectly normal. The nviz program is simply a customized version of
> the Tcl/Tk "wish" executable. Try executing "wish" on the command line
> and you should see the same prompt.
> As for it crashing when it is run in the background, I have no idea. You
> might try changing GRASS_MESSAGE_FORMAT environment variable to see if
> that has any effect.
> It might help to know what platform and Tcl/Tk version it is failing on.
> For me it works on RedHat 7.3 with Tk8.3, and RedHat 9 with Tk8.4.
> Bob
> Helena wrote:
> >Huidae Cho wrote:
> >>Hi,
> >>I noticed today that nviz doesn't work if I run it background as before.
> >>Similarly, it just stops after displaying a map when it's executed from
> >>"d.m &" which is recommended in the welcome message.
> >>nviz elevation=dem &    # doesn't work
> >>d.m &            # nviz doesn't work
> >>nviz elevation=dem    # works!
> >>d.m            # nviz works!
> >>And I see nviz prints % prompt. Does anyone have a clue?
> >It must be the latest change that was done - I just tried it and it
> >does not work even if I do nviz elevation=dem, it displays the DEM
> >but fails to open the Main pannel and prints a % prompt.
> >It worked OK just a few days (weeks?) ago.
> >It may be related to the change in the startup script - Bob, are you
> >around? How does it work for you?
> >Helena
> >>Thanks.
> >>Huidae Cho
> >>_______________________________________________
> >>grass5 mailing list
> >>grass5 at grass.itc.it
> >>http://grass.itc.it/mailman/listinfo/grass5
