[GRASS5] nviz problem
Bob Covill
bcovill at tekmap.ns.ca
Mon Dec 20 13:28:27 EST 2004
The script is mean't as a temporary fix so that you can run nviz with
options in the background (&). Try "./i -q &" and nviz should start up
in quick mode running in the background.
Nviz uses both G_parser and wish style arguments. In other words nviz is
a customized version of wish that accepts GRASS style commands. The
trick is to make sure that the GRASS commands are not stripped out by
the TK wish portion. The "-f" flag tells it to execute the script
(nviz2.2_script in our case) in the same way that wish would execute a
script. Remember that the current nviz executable is simply the old
NVWISH renamed.
The problem seems to be related to the fact that nviz2.2_script is
currently executed internally with Tcl_Eval. If nviz is executed in the
background the whole thing hangs up. The trick is to figure out how to
call this correctly?
Bob
Huidae Cho wrote:
> Hi,
> Your fix doesn't work:
> GRASS 5.7.cvs:~/tmp > cat i
> #!/bin/sh
> exec nviz -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script "$@"
> GRASS 5.7.cvs:~/tmp > ./i
> Illegal filename. character </> not allowed.Error: Raster
/home/geni/usr/grass/grass51/dist.i686-pc-cygwin/etc/nviz2.2/scripts/nviz2.2_script
does not exist in current Mapset
> Load Failed
> nviz2.2_script is not a map but a script. The error message comes
from the
> grass parser library not from tcl/tk. I think nviz is a grass module
itself,
> so it doesn't accept parameters except grass ones.
> If -f option is given:
> nviz -f nviz_script grass parameters
> Otherwise:
> nviz -- grass parameters
> This is what I understand, but where does nviz do something for "-f"
> option? I cannot find it.
> When I run "nviz -f elev=dem500" which should be wrong, nviz displays
> dem500 and tries to find "elev=dem500" script without success:
> Loading Data
> translating colors from fp
> recalculating normals...
> Error in startup script: couldn't read file "elev=dem500": no such file
> or directory
> I think the tcl/tk parser conflicts with the grass parser and maybe
> tcl/tk sould have a priority here.
> Thank you.
> Huidae Cho
> On Mon, Dec 20, 2004 at 09:18:11AM -0400, Bob Covill wrote:
>>Hi,
>>I was finally able to duplicate the background error on my RedHat 7.3
>>system. For some reason it works fine on my RedHat 9 system.
>>I have searched the Tcl/Tk archives for documentation of similar
>>problems, but found nothing.
>>In the meantime I have got the following script to work.
>>#!/bin/sh
>>This seems to work if started in the foreground or background, but I
>>have not tested it properly. In order to use the above script you have
>>to first edit nviz_init.c in visualization/nviz/src and comment out the
>>following line ...
>> if (!script_mode)
>> Tcl_Eval(interp, nviz_script); /* source nviz_script to
>>start main window */
>>After commenting, rebuild nviz and run the above script. Hopefully this
>>will work for you.
>>Now that I have an idea of where the problem is originating, hopefully I
>>can figure out a more permanent solution. Suggestions welcome.
>>Bob
>>Huidae Cho wrote:
>>>Hi, output is the following:
>>>GRASS 5.7.cvs:~/tmp > cat a
>>>#!/bin/sh
>>>exec nviz "$0" "$@"
>>>GRASS 5.7.cvs:~/tmp > ./a elev=dem&
>>>[1] 1112
>>>GRASS 5.7.cvs:~/tmp > Loading Data
>>>Loading Data
>>>translating colors
>>>% w 100
>>>[1]+ Stopped ./a elev=dem
>>>It stops just after displaying map and empty control windows and
>>>if I "fg", it starts working again.
>>>I think behavior is not consistent from system to system.
>>>Huidae Cho
>>>On Sat, Dec 18, 2004 at 04:29:33PM +0000, Bob Covill wrote:
>>>>Hi,
>>>>This is an interesting one. If I execute something like "nviz -q
&", nviz
>>>>starts up normally with the wish (%) prompt. If I hit enter at the
prompt
>>>>I
>>>>am returned to the normal command line prompt and can run other
commands
>>>>(while nviz is running). When I quit nviz I get the respone on the
command
>>>>line ...
>>>>[1]+ Done nviz -q
>>>>which is what I would expect from a command that has been running
in the
>>>>background.
>>>>Out of curiousity try creating a simple startup script with the
following:
>>>>#!/bin/sh
>>>>exec nviz "$0" "$@"
>>>>Make it executable and try running it in the background. For
example if
>>>>you
>>>>name the script nv_start.sh, try "nv_start.sh elev=dem &" and see
if that
>>>>works.
>>>>Bob
>>>>On 12/18/2004, "Huidae Cho" <grass4u at gmail.com> wrote:
>>>>>Interesting!
>>>>>Is wish running in background? As I know, a shell-like program
cannot be
>>>>>running in that way because if it's bg'ed or run with "&", /bin/sh or
>>>>>the login shell takes control of stdin so that users can stay in the
>>>>>login
>>>>>shell.
>>>>>If it's executed by a script, then it's ok because it's a usual shell
>>>>>script.
>>>>>Do you mean running "nviz" and executing other programs in the "%"
nviz
>>>>>prompt instead of running "nviz &"?
>>>>>If wish is running in background (wish &), how can you execute wish
>>>>functions?
>>>>>Thank you.
>>>>>Huidae Cho
>>>>>On Sat, Dec 18, 2004 at 01:22:50PM +0000, Bob Covill wrote:
>>>>>>Hi,
>>>>>>It appears that not even wish will run in the background on your
system
>>>>>>very strange.
>>>>>>The current nviz IS the old NVWISH executable which was called was
>>>>>>called
>>>>by
>>>>>>the old nviz shell script. The reason I got rid of the shell
script was
>>>>>>because when nviz encountered an error the same un-informitive
message
>>>>was
>>>>>>generated because it was passed through the script. Also, there are a
>>>>number
>>>>>>of error catches in the actual nviz tcl scripts which were completely
>>>>ignored
>>>>>>with the old shell startup.
>>>>>>Before reverting to the old startup it would be nice to know why wish
>>>>(and
>>>>>>nviz) will not run in the background on some systems. On both of my
>>>>RedHat
>>>>>>systems it runs fine both in the background and the foreground.
>>>>>>Bob
>>>>>>>Hi,
>>>>>>>Now nviz is not a *wish script but a shell itself. That's why it
prints
>>>>>>>a prompt and we cannot execute it background and inside "d.m &".
To fix
>>>>>>>this problem, I think we should go back to NVWISH because
running nviz
>>>>>>>foreground is pain.
>>>>>>>You can test this:
>>>>>>> wish &
>>>>>>>prints % prompt and just stop!
>>>>>>>Huidae Cho
>>>>>>>On Fri, Dec 17, 2004 at 09:02:39PM -0400, Bob Covill wrote:
>>>>>>>>Hello,
>>>>>>>>I tried running the latest version of nviz in the background with
>>>>>>>>various options and it seems to work fine. The "%" prompt that
you see
>>>>>>>>is perfectly normal. The nviz program is simply a customized
version
>>>>of
>>>>>>>>the Tcl/Tk "wish" executable. Try executing "wish" on the
command line
>>>>>>>>and you should see the same prompt.
>>>>>>>>As for it crashing when it is run in the background, I have no
idea.
>>>>You
>>>>>>>>might try changing GRASS_MESSAGE_FORMAT environment variable to
see if
>>>>>>>>that has any effect.
>>>>>>>>It might help to know what platform and Tcl/Tk version it is
failing
>>>>on.
>>>>>>>>For me it works on RedHat 7.3 with Tk8.3, and RedHat 9 with Tk8.4.
>>>>>>>>Bob
>>>>>>>>Helena wrote:
>>>>>>>>>Huidae Cho wrote:
>>>>>>>>>>Hi,
>>>>>>>>>>I noticed today that nviz doesn't work if I run it background as
>>>>>>before.
>>>>>>>>>>Similarly, it just stops after displaying a map when it's
executed
>>>>from
>>>>>>>>>>"d.m &" which is recommended in the welcome message.
>>>>>>>>>>nviz elevation=dem & # doesn't work
>>>>>>>>>>d.m & # nviz doesn't work
>>>>>>>>>>nviz elevation=dem # works!
>>>>>>>>>>d.m # nviz works!
>>>>>>>>>>And I see nviz prints % prompt. Does anyone have a clue?
>>>>>>>>>It must be the latest change that was done - I just tried it
and it
>>>>>>>>>does not work even if I do nviz elevation=dem, it displays the DEM
>>>>>>>>>but fails to open the Main pannel and prints a % prompt.
>>>>>>>>>It worked OK just a few days (weeks?) ago.
>>>>>>>>>It may be related to the change in the startup script - Bob,
are you
>>>>>>>>>around? How does it work for you?
>>>>>>>>>Helena
>>>>>>>>>>Thanks.
>>>>>>>>>>Huidae Cho
>>>>>>>>>>_______________________________________________
>>>>>>>>>>grass5 mailing list
>>>>>>>>>>grass5 at grass.itc.it
>>>>>>>>>>http://grass.itc.it/mailman/listinfo/grass5
>>>>>grass5 mailing list
>>Bob Covill
>>Tekmap Consulting
>>P.O. Box 2016
>>Fall River, N.S.
>>B2T 1K6
>>Canada
>>E-Mail: bcovill at tekmap.ns.ca
>>Phone: 902-860-1496
>>Fax: 902-860-1498
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
Phone: 902-860-1496
Fax: 902-860-1498
