[GRASS5] nviz problem
Bob Covill
bcovill at tekmap.ns.ca
Mon Dec 20 08:18:11 EST 2004
I was finally able to duplicate the background error on my RedHat 7.3
system. For some reason it works fine on my RedHat 9 system.
I have searched the Tcl/Tk archives for documentation of similar
problems, but found nothing.
In the meantime I have got the following script to work.
#!/bin/sh
exec nviz -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script "$@"
This seems to work if started in the foreground or background, but I
have not tested it properly. In order to use the above script you have
to first edit nviz_init.c in visualization/nviz/src and comment out the
following line ...
if (!script_mode)
Tcl_Eval(interp, nviz_script); /* source nviz_script to
start main window */
After commenting, rebuild nviz and run the above script. Hopefully this
will work for you.
Now that I have an idea of where the problem is originating, hopefully I
can figure out a more permanent solution. Suggestions welcome.
Bob
Huidae Cho wrote:
> Hi, output is the following:
> GRASS 5.7.cvs:~/tmp > cat a
> #!/bin/sh
> exec nviz "$0" "$@"
> GRASS 5.7.cvs:~/tmp > ./a elev=dem&
> [1] 1112
> GRASS 5.7.cvs:~/tmp > Loading Data
> Loading Data
> translating colors
> recalculating normals...
> % w 100
> [1]+ Stopped ./a elev=dem
> It stops just after displaying map and empty control windows and
> if I "fg", it starts working again.
> I think behavior is not consistent from system to system.
> Huidae Cho
> On Sat, Dec 18, 2004 at 04:29:33PM +0000, Bob Covill wrote:
>>Hi,
>>This is an interesting one. If I execute something like "nviz -q &", nviz
>>starts up normally with the wish (%) prompt. If I hit enter at the prompt I
>>am returned to the normal command line prompt and can run other commands
>>(while nviz is running). When I quit nviz I get the respone on the command
>>line ...
>>[1]+ Done nviz -q
>>which is what I would expect from a command that has been running in the
>>background.
>>Out of curiousity try creating a simple startup script with the following:
>>#!/bin/sh
>>exec nviz "$0" "$@"
>>Make it executable and try running it in the background. For example if you
>>name the script nv_start.sh, try "nv_start.sh elev=dem &" and see if that
>>works.
>>Bob
>>On 12/18/2004, "Huidae Cho" <grass4u at gmail.com> wrote:
>>>Interesting!
>>>Is wish running in background? As I know, a shell-like program cannot be
>>>running in that way because if it's bg'ed or run with "&", /bin/sh or
>>>the login shell takes control of stdin so that users can stay in the login
>>>shell.
>>>If it's executed by a script, then it's ok because it's a usual shell
>>>script.
>>>Do you mean running "nviz" and executing other programs in the "%" nviz
>>>prompt instead of running "nviz &"?
>>>If wish is running in background (wish &), how can you execute wish
>>functions?
>>>Thank you.
>>>Huidae Cho
>>>On Sat, Dec 18, 2004 at 01:22:50PM +0000, Bob Covill wrote:
>>>>Hi,
>>>>It appears that not even wish will run in the background on your system
>>>>very strange.
>>>>The current nviz IS the old NVWISH executable which was called was called
>>by
>>>>the old nviz shell script. The reason I got rid of the shell script was
>>>>because when nviz encountered an error the same un-informitive message
>>was
>>>>generated because it was passed through the script. Also, there are a
>>number
>>>>of error catches in the actual nviz tcl scripts which were completely
>>ignored
>>>>with the old shell startup.
>>>>Before reverting to the old startup it would be nice to know why wish
>>(and
>>>>nviz) will not run in the background on some systems. On both of my
>>RedHat
>>>>systems it runs fine both in the background and the foreground.
>>>>Bob
>>>>>Hi,
>>>>>Now nviz is not a *wish script but a shell itself. That's why it prints
>>>>>a prompt and we cannot execute it background and inside "d.m &". To fix
>>>>>this problem, I think we should go back to NVWISH because running nviz
>>>>>foreground is pain.
>>>>>You can test this:
>>>>> wish &
>>>>>prints % prompt and just stop!
>>>>>Huidae Cho
>>>>>On Fri, Dec 17, 2004 at 09:02:39PM -0400, Bob Covill wrote:
>>>>>>Hello,
>>>>>>I tried running the latest version of nviz in the background with
>>>>>>various options and it seems to work fine. The "%" prompt that you see
>>>>>>is perfectly normal. The nviz program is simply a customized version
>>of
>>>>>>the Tcl/Tk "wish" executable. Try executing "wish" on the command line
>>>>>>and you should see the same prompt.
>>>>>>As for it crashing when it is run in the background, I have no idea.
>>You
>>>>>>might try changing GRASS_MESSAGE_FORMAT environment variable to see if
>>>>>>that has any effect.
>>>>>>It might help to know what platform and Tcl/Tk version it is failing
>>on.
>>>>>>For me it works on RedHat 7.3 with Tk8.3, and RedHat 9 with Tk8.4.
>>>>>>Bob
>>>>>>Helena wrote:
>>>>>>>Huidae Cho wrote:
>>>>>>>>Hi,
>>>>>>>>I noticed today that nviz doesn't work if I run it background as
>>>>before.
>>>>>>>>Similarly, it just stops after displaying a map when it's executed
>>from
>>>>>>>>"d.m &" which is recommended in the welcome message.
>>>>>>>>nviz elevation=dem & # doesn't work
>>>>>>>>d.m & # nviz doesn't work
>>>>>>>>nviz elevation=dem # works!
>>>>>>>>d.m # nviz works!
>>>>>>>>And I see nviz prints % prompt. Does anyone have a clue?
>>>>>>>It must be the latest change that was done - I just tried it and it
>>>>>>>does not work even if I do nviz elevation=dem, it displays the DEM
>>>>>>>but fails to open the Main pannel and prints a % prompt.
>>>>>>>It worked OK just a few days (weeks?) ago.
>>>>>>>It may be related to the change in the startup script - Bob, are you
>>>>>>>around? How does it work for you?
>>>>>>>Helena
>>>>>>>>Thanks.
>>>>>>>>Huidae Cho
>>>>>>>>_______________________________________________
>>>>>>>>grass5 mailing list
>>>>>>>>grass5 at grass.itc.it
>>>>>>>>http://grass.itc.it/mailman/listinfo/grass5
>>>grass5 mailing list
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
