[GRASS5] nviz problem
Michael Barton
michael.barton at asu.edu
Sat Dec 18 16:51:11 EST 2004
I want to add a report that might (or I suppose might not) help to clarify
what is happening.
I am at home and running a 2 December version of GRASS 5.7 cvs on my Mac OSX
laptop. I have a newer version on my lab Mac but can't get at it at the
moment. However, one of my grad students has been doing a lot with nviz in
the last couple days on a 13 December version of GRASS 5.7 cvs and (without
systematic testing) it seems to behave the same.
When I run nviz from the GUI it runs fine. This is using the 'execute'
procedure which is essentially exec [cmd] &, which brings up the
autogenerated GUI dialog. Whether I add a raster (or other) map or run it
with the -q flag from this environment, it runs in the background without
any problems
When I run nviz from the GRASS command prompt it runs exactly the same as
above *IF* I simply type nviz [return], bringing up the autogenerated GUI.
However, if I type from the GRASS command prompt "nviz -q & [return]", it
runs differently. NVIZ works fine UNTIL I return to the command prompt and
hit [return]. I've copied the terminal output below. Note that it goes to
the Wish "%" prompt (this doesn't happen if I start nviz either of the other
2 ways).
GRASS 5.7.cvs:~ > nviz -q &
[1] 1503
GRASS 5.7.cvs:~ > *** malloc[1503]: Deallocation of a pointer not malloced:
0x29e4248; This could be a double free(), or free() called with the middle
of an allocated block; Try setting environment variable MallocHelp to see
tools to help debug
*** malloc[1503]: Deallocation of a pointer not malloced: 0x2b7e108; This
could be a double free(), or free() called with the middle of an allocated
block; Try setting environment variable MallocHelp to see tools to help
debug
[1]+ Stopped nviz -q
GRASS 5.7.cvs:~ >
At this point nviz freezes. I can't get it to do anything and I can't quit
it. The rest of GRASS works fine, both from the command prompt and from the
tcltk GIS Manager. However, the only way I can quit nviz is to completely
exit X-11 on my Mac.
I hope this helps.
Michael
On 12/18/04 11:36 AM, "Huidae Cho" <grass4u at gmail.com> wrote:
> Hi, output is the following:
> GRASS 5.7.cvs:~/tmp > cat a
> #!/bin/sh
> exec nviz "$0" "$@"
> GRASS 5.7.cvs:~/tmp > ./a elev=dem&
> [1] 1112
> GRASS 5.7.cvs:~/tmp > Loading Data
> Loading Data
> translating colors
> recalculating normals...
> % w 100
> [1]+ Stopped ./a elev=dem
> It stops just after displaying map and empty control windows and
> if I "fg", it starts working again.
> I think behavior is not consistent from system to system.
> Huidae Cho
> On Sat, Dec 18, 2004 at 04:29:33PM +0000, Bob Covill wrote:
>> Hi,
>> This is an interesting one. If I execute something like "nviz -q &", nviz
>> starts up normally with the wish (%) prompt. If I hit enter at the prompt I
>> am returned to the normal command line prompt and can run other commands
>> (while nviz is running). When I quit nviz I get the respone on the command
>> line ...
>> [1]+ Done nviz -q
>> which is what I would expect from a command that has been running in the
>> background.
>> Out of curiousity try creating a simple startup script with the following:
>> #!/bin/sh
>> exec nviz "$0" "$@"
>> Make it executable and try running it in the background. For example if you
>> name the script nv_start.sh, try "nv_start.sh elev=dem &" and see if that
>> works.
>> Bob
>> On 12/18/2004, "Huidae Cho" <grass4u at gmail.com> wrote:
>>> Interesting!
>>> Is wish running in background? As I know, a shell-like program cannot be
>>> running in that way because if it's bg'ed or run with "&", /bin/sh or
>>> the login shell takes control of stdin so that users can stay in the login
>>> shell.
>>> If it's executed by a script, then it's ok because it's a usual shell
>>> script.
>>> Do you mean running "nviz" and executing other programs in the "%" nviz
>>> prompt instead of running "nviz &"?
>>> If wish is running in background (wish &), how can you execute wish
>> functions?
>>> Thank you.
>>> Huidae Cho
>>> On Sat, Dec 18, 2004 at 01:22:50PM +0000, Bob Covill wrote:
>>>> Hi,
>>>> It appears that not even wish will run in the background on your system
>>>> very strange.
>>>> The current nviz IS the old NVWISH executable which was called was called
>> by
>>>> the old nviz shell script. The reason I got rid of the shell script was
>>>> because when nviz encountered an error the same un-informitive message
>> was
>>>> generated because it was passed through the script. Also, there are a
>> number
>>>> of error catches in the actual nviz tcl scripts which were completely
>> ignored
>>>> with the old shell startup.
>>>> Before reverting to the old startup it would be nice to know why wish
>> (and
>>>> nviz) will not run in the background on some systems. On both of my
>> RedHat
>>>> systems it runs fine both in the background and the foreground.
>>>> Bob
>>>>> Hi,
>>>>> Now nviz is not a *wish script but a shell itself. That's why it prints
>>>>> a prompt and we cannot execute it background and inside "d.m &". To fix
>>>>> this problem, I think we should go back to NVWISH because running nviz
>>>>> foreground is pain.
>>>>> You can test this:
>>>>> wish &
>>>>> prints % prompt and just stop!
>>>>> Huidae Cho
>>>>> On Fri, Dec 17, 2004 at 09:02:39PM -0400, Bob Covill wrote:
>>>>>> Hello,
>>>>>> I tried running the latest version of nviz in the background with
>>>>>> various options and it seems to work fine. The "%" prompt that you see
>>>>>> is perfectly normal. The nviz program is simply a customized version
>> of
>>>>>> the Tcl/Tk "wish" executable. Try executing "wish" on the command line
>>>>>> and you should see the same prompt.
>>>>>> As for it crashing when it is run in the background, I have no idea.
>> You
>>>>>> might try changing GRASS_MESSAGE_FORMAT environment variable to see if
>>>>>> that has any effect.
>>>>>> It might help to know what platform and Tcl/Tk version it is failing
>> on.
>>>>>> For me it works on RedHat 7.3 with Tk8.3, and RedHat 9 with Tk8.4.
>>>>>> Bob
>>>>>> Helena wrote:
>>>>>>> Huidae Cho wrote:
>>>>>>>> Hi,
>>>>>>>> I noticed today that nviz doesn't work if I run it background as
>>>> before.
>>>>>>>> Similarly, it just stops after displaying a map when it's executed
>> from
>>>>>>>> "d.m &" which is recommended in the welcome message.
>>>>>>>> nviz elevation=dem & # doesn't work
>>>>>>>> d.m & # nviz doesn't work
>>>>>>>> nviz elevation=dem # works!
>>>>>>>> d.m # nviz works!
>>>>>>>> And I see nviz prints % prompt. Does anyone have a clue?
>>>>>>> It must be the latest change that was done - I just tried it and it
>>>>>>> does not work even if I do nviz elevation=dem, it displays the DEM
>>>>>>> but fails to open the Main pannel and prints a % prompt.
>>>>>>> It worked OK just a few days (weeks?) ago.
>>>>>>> It may be related to the change in the startup script - Bob, are you
>>>>>>> around? How does it work for you?
>>>>>>> Helena
>>>>>>>> Thanks.
>>>>>>>> Huidae Cho
>>>>>>>> _______________________________________________
>>>>>>>> grass5 mailing list
>>>>>>>> grass5 at grass.itc.it
>>>>>>>> http://grass.itc.it/mailman/listinfo/grass5
>>> grass5 mailing list
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
