[GRASS5] nviz problem
Huidae Cho grass4u at gmail.com
Sat Dec 18 13:36:08 EST 2004
Hi, output is the following:
GRASS 5.7.cvs:~/tmp > cat a
#!/bin/sh
exec nviz "$0" "$@"
GRASS 5.7.cvs:~/tmp > ./a elev=dem&
[1] 1112
GRASS 5.7.cvs:~/tmp > Loading Data
Loading Data
translating colors
recalculating normals...
% w 100
[1]+  Stopped                 ./a elev=dem
It stops just after displaying map and empty control windows and
if I "fg", it starts working again.
I think behavior is not consistent from system to system.
Huidae Cho
On Sat, Dec 18, 2004 at 04:29:33PM +0000, Bob Covill wrote:
> Hi,
> This is an interesting one. If I execute something like "nviz -q &", nviz
> starts up normally with the wish (%) prompt. If I hit enter at the prompt I
> am returned to the normal command line prompt and can run other commands
> (while nviz is running). When I quit nviz I get the respone on the command
> line ...
> [1]+  Done                    nviz -q
> which is what I would expect from a command that has been running in the
> background.
> Out of curiousity try creating a simple startup script with the following:
> #!/bin/sh
> exec nviz "$0" "$@"
> Make it executable and try running it in the background. For example if you
> name the script nv_start.sh, try "nv_start.sh elev=dem &" and see if that
> works.
> Bob
> On 12/18/2004, "Huidae Cho" <grass4u at gmail.com> wrote:
> >Interesting!
> >Is wish running in background? As I know, a shell-like program cannot be
> >running in that way because if it's bg'ed or run with "&", /bin/sh or
> >the login shell takes control of stdin so that users can stay in the login
> >shell.
> >If it's executed by a script, then it's ok because it's a usual shell
> >script.
> >Do you mean running "nviz" and executing other programs in the "%" nviz
> >prompt instead of running "nviz &"?
> >If wish is running in background (wish &), how can you execute wish
> functions?
> >Thank you.
> >Huidae Cho
> >On Sat, Dec 18, 2004 at 01:22:50PM +0000, Bob Covill wrote:
> >> Hi,
> >> It appears that not even wish will run in the background on your system
> >> very strange.
> >> The current nviz IS the old NVWISH executable which was called was called
> by
> >> the old nviz shell script. The reason I got rid of the shell script was
> >> because when nviz encountered an error the same un-informitive message
> was
> >> generated because it was passed through the script. Also, there are a
> number
> >> of error catches in the actual nviz tcl scripts which were completely
> ignored
> >> with the old shell startup.
> >> Before reverting to the old startup it would be nice to know why wish
> (and
> >> nviz) will not run in the background on some systems. On both of my
> RedHat
> >> systems it runs fine both in the background and the foreground.
> >> Bob
> >> >Hi,
> >> >Now nviz is not a *wish script but a shell itself. That's why it prints
> >> >a prompt and we cannot execute it background and inside "d.m &". To fix
> >> >this problem, I think we should go back to NVWISH because running nviz
> >> >foreground is pain.
> >> >You can test this:
> >> >	wish &
> >> >prints % prompt and just stop!
> >> >Huidae Cho
> >> >On Fri, Dec 17, 2004 at 09:02:39PM -0400, Bob Covill wrote:
> >> >> Hello,
> >> >> I tried running the latest version of nviz in the background with
> >> >> various options and it seems to work fine. The "%" prompt that you see
> >> >> is perfectly normal. The nviz program is simply a customized version
> of
> >> >> the Tcl/Tk "wish" executable. Try executing "wish" on the command line
> >> >> and you should see the same prompt.
> >> >> As for it crashing when it is run in the background, I have no idea.
> You
> >> >> might try changing GRASS_MESSAGE_FORMAT environment variable to see if
> >> >> that has any effect.
> >> >> It might help to know what platform and Tcl/Tk version it is failing
> on.
> >> >> For me it works on RedHat 7.3 with Tk8.3, and RedHat 9 with Tk8.4.
> >> >> Bob
> >> >> Helena wrote:
> >> >> >Huidae Cho wrote:
> >> >> >>Hi,
> >> >> >>I noticed today that nviz doesn't work if I run it background as
> >> before.
> >> >> >>Similarly, it just stops after displaying a map when it's executed
> from
> >> >> >>"d.m &" which is recommended in the welcome message.
> >> >> >>nviz elevation=dem &    # doesn't work
> >> >> >>d.m &            # nviz doesn't work
> >> >> >>nviz elevation=dem    # works!
> >> >> >>d.m            # nviz works!
> >> >> >>And I see nviz prints % prompt. Does anyone have a clue?
> >> >> >It must be the latest change that was done - I just tried it and it
> >> >> >does not work even if I do nviz elevation=dem, it displays the DEM
> >> >> >but fails to open the Main pannel and prints a % prompt.
> >> >> >It worked OK just a few days (weeks?) ago.
> >> >> >It may be related to the change in the startup script - Bob, are you
> >> >> >around? How does it work for you?
> >> >> >Helena
> >> >> >>Thanks.
> >> >> >>Huidae Cho
> >> >> >>_______________________________________________
> >> >> >>grass5 mailing list
> >> >> >>grass5 at grass.itc.it
> >> >> >>http://grass.itc.it/mailman/listinfo/grass5
> >grass5 mailing list
