[GRASS5] nviz problem
Bob Covill
bcovill at tekmap.ns.ca
Sat Dec 18 11:29:33 EST 2004
This is an interesting one. If I execute something like "nviz -q &", nviz
starts up normally with the wish (%) prompt. If I hit enter at the prompt I
am returned to the normal command line prompt and can run other commands
(while nviz is running). When I quit nviz I get the respone on the command
line ...
[1]+ Done nviz -q
which is what I would expect from a command that has been running in the
background.
Out of curiousity try creating a simple startup script with the following:
#!/bin/sh
exec nviz "$0" "$@"
Make it executable and try running it in the background. For example if you
name the script nv_start.sh, try "nv_start.sh elev=dem &" and see if that
works.
Bob
On 12/18/2004, "Huidae Cho" <grass4u at gmail.com> wrote:
>Interesting!
>Is wish running in background? As I know, a shell-like program cannot be
>running in that way because if it's bg'ed or run with "&", /bin/sh or
>the login shell takes control of stdin so that users can stay in the login
>shell.
>If it's executed by a script, then it's ok because it's a usual shell
>script.
>Do you mean running "nviz" and executing other programs in the "%" nviz
>prompt instead of running "nviz &"?
>If wish is running in background (wish &), how can you execute wish
functions?
>Thank you.
>Huidae Cho
>On Sat, Dec 18, 2004 at 01:22:50PM +0000, Bob Covill wrote:
>> Hi,
>> It appears that not even wish will run in the background on your system
>> very strange.
>> The current nviz IS the old NVWISH executable which was called was called
by
>> the old nviz shell script. The reason I got rid of the shell script was
>> because when nviz encountered an error the same un-informitive message
was
>> generated because it was passed through the script. Also, there are a
number
>> of error catches in the actual nviz tcl scripts which were completely
ignored
>> with the old shell startup.
>> Before reverting to the old startup it would be nice to know why wish
(and
>> nviz) will not run in the background on some systems. On both of my
RedHat
>> systems it runs fine both in the background and the foreground.
>> Bob
>> >Hi,
>> >Now nviz is not a *wish script but a shell itself. That's why it prints
>> >a prompt and we cannot execute it background and inside "d.m &". To fix
>> >this problem, I think we should go back to NVWISH because running nviz
>> >foreground is pain.
>> >You can test this:
>> > wish &
>> >prints % prompt and just stop!
>> >Huidae Cho
>> >On Fri, Dec 17, 2004 at 09:02:39PM -0400, Bob Covill wrote:
>> >> Hello,
>> >> I tried running the latest version of nviz in the background with
>> >> various options and it seems to work fine. The "%" prompt that you see
>> >> is perfectly normal. The nviz program is simply a customized version
of
>> >> the Tcl/Tk "wish" executable. Try executing "wish" on the command line
>> >> and you should see the same prompt.
>> >> As for it crashing when it is run in the background, I have no idea.
You
>> >> might try changing GRASS_MESSAGE_FORMAT environment variable to see if
>> >> that has any effect.
>> >> It might help to know what platform and Tcl/Tk version it is failing
on.
>> >> For me it works on RedHat 7.3 with Tk8.3, and RedHat 9 with Tk8.4.
>> >> Bob
>> >> Helena wrote:
>> >> >Huidae Cho wrote:
>> >> >>Hi,
>> >> >>I noticed today that nviz doesn't work if I run it background as
>> before.
>> >> >>Similarly, it just stops after displaying a map when it's executed
from
>> >> >>"d.m &" which is recommended in the welcome message.
>> >> >>nviz elevation=dem & # doesn't work
>> >> >>d.m & # nviz doesn't work
>> >> >>nviz elevation=dem # works!
>> >> >>d.m # nviz works!
>> >> >>And I see nviz prints % prompt. Does anyone have a clue?
>> >> >It must be the latest change that was done - I just tried it and it
>> >> >does not work even if I do nviz elevation=dem, it displays the DEM
>> >> >but fails to open the Main pannel and prints a % prompt.
>> >> >It worked OK just a few days (weeks?) ago.
>> >> >It may be related to the change in the startup script - Bob, are you
>> >> >around? How does it work for you?
>> >> >Helena
>> >> >>Thanks.
>> >> >>Huidae Cho
>> >> >>_______________________________________________
>> >> >>grass5 mailing list
>> >> >>grass5 at grass.itc.it
>> >> >>http://grass.itc.it/mailman/listinfo/grass5
>grass5 mailing list
