[GRASS5] form mode for d.what.vect
Florian Goessmann florian at wallweg39.de
Thu Dec 23 03:09:56 EST 2004
it didn't work for me. same error as before.
florian
On 23 Dec 2004, at 04:12, Michael Barton wrote:
> Moritz Lennart seemed to have found a way to make the form mode work
> correctly for Mac’s (see below). Has anyone had a chance to test this?
> Is this something that works across all platforms or is it
> problematic?
>  Michael
>  ____________________
>  C. Michael Barton, Professor of Anthropology
>  School of Human Evolution and Social Change
>  PO Box 872402
>  Arizona State University
>  Tempe, AZ  85287-2402
>  USA
>  Phone: 480-965-6262
>  Fax: 480-965-7671
>  www: <www.public.asu.edu/~cmbarton>
> ------ Forwarded Message
> From: Michael Barton <Michael.Barton at asu.edu>
> Date: Tue, 23 Nov 2004 10:40:53 -0700
> To: <mlennert at club.worldonline.be>
> Cc: <blazek at itc.it>
> Subject: Re: [GRASS5] d.m - d.what.vect
> Will this work for everyone? If so, can we make it the standard?
>  Michael
>  On 11/23/04 10:05 AM, "Moritz Lennert" <mlennert at club.worldonline.be>
> wrote:
>  > On Tue, November 23, 2004 17:41, Michael Barton said:
>  >> Thanks Moritz.
>  >> I really wish someone would find a way to fix this. I'd like to
> use the form
>  >> mode on my Mac. I promise to change the toolbar to form mode as
> soon as it
>  >> gets fixed.
>  > As you can see in the thread, I fixed it for me by adding
>  > sleep(1);
>  > to the main() function of the main.c file of d.what.vect:
>  > int main(int argc, char **argv)
>  >   struct Flag *once, *terse, *txt, *topo_flag, *flash, *edit_flag;
>  >   struct Option *opt1;
>  >   struct GModule *module;
>  >   char *mapset, *openvect();
>  >   char temp[128], *str;
>  >   int i, j, level, width = 0, mwidth = 0;
>  >   sleep(1);
>  >   /* Initialize the GIS calls */
>  >   G_gisinit (argv[0]) ;
>  > This is just a hack, but it works for me !
>  > Moritz
>  >> Michael
>  >> On 11/23/04 9:21 AM, "Moritz Lennert"
> <mlennert at club.worldonline.be> wrote:
>  >>> On Tue, November 23, 2004 15:47, Radim Blazek said:
>  >>>> Why d.what.vect is run with -x flag in d.m?
> http://freegis.org/cgi-bin/viewcvs.cgi/grass51/display/d.m/
> vector.tcl.diff?
>  >>>> r1
>  >>>> =1.27&r2=1.28
>  >>> Because some of us have problems with d.what.vect and the form
> library
>  >>> making
>  >>> it unusable in GUI mode (unless you add a sleep(1) in main.c:
>  >>> http://grass.itc.it/pipermail/grass5/2004-September/015393.html
>  >>> and
>  >>> http://grass.itc.it/pipermail/grass5/2004-October/015746.html
>  >>> Moritz
>  >> ______________________________
>  >> School of Human, Evolution and Social Change
>  >> USA
>  >> voice: 480-965-6262; fax: 480-965-7671
>  >> www: http://www.public.asu.edu/~cmbarton
>  USA
>  ------ End of Forwarded Message
