FW: [GRASS5] form mode for d.what.vect
Michael Barton
michael.barton at asu.edu
Wed Dec 22 22:12:51 EST 2004
Moritz Lennart seemed to have found a way to make the form mode work
correctly for Mac¹s (see below). Has anyone had a chance to test this? Is
this something that works across all platforms or is it problematic?
Michael
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
> ------ Forwarded Message
> From: Michael Barton <Michael.Barton at asu.edu>
> Date: Tue, 23 Nov 2004 10:40:53 -0700
> To: <mlennert at club.worldonline.be>
> Cc: <blazek at itc.it>
> Subject: Re: [GRASS5] d.m - d.what.vect
> Will this work for everyone? If so, can we make it the standard?
> Michael
> On 11/23/04 10:05 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
>> > On Tue, November 23, 2004 17:41, Michael Barton said:
>>> >> Thanks Moritz.
>>> >> I really wish someone would find a way to fix this. I'd like to use the
>>> form
>>> >> mode on my Mac. I promise to change the toolbar to form mode as soon as
it
>>> >> gets fixed.
>> > As you can see in the thread, I fixed it for me by adding
>> > sleep(1);
>> > to the main() function of the main.c file of d.what.vect:
>> > int main(int argc, char **argv)
>> > struct Flag *once, *terse, *txt, *topo_flag, *flash, *edit_flag;
>> > struct Option *opt1;
>> > struct GModule *module;
>> > char *mapset, *openvect();
>> > char temp[128], *str;
>> > int i, j, level, width = 0, mwidth = 0;
>> > sleep(1);
>> > /* Initialize the GIS calls */
>> > G_gisinit (argv[0]) ;
>> > This is just a hack, but it works for me !
>> > Moritz
>>> >> Michael
>>> >> On 11/23/04 9:21 AM, "Moritz Lennert" <mlennert at club.worldonline.be>
>>> wrote:
>>>> >>> On Tue, November 23, 2004 15:47, Radim Blazek said:
>>>>> >>>> Why d.what.vect is run with -x flag in d.m?
http://freegis.org/cgi-bin/viewcvs.cgi/grass51/display/d.m/vector.tcl.diff?
>>>>> >>>> r1
>>>>> >>>> =1.27&r2=1.28
>>>> >>> Because some of us have problems with d.what.vect and the form library
>>>> >>> making
>>>> >>> it unusable in GUI mode (unless you add a sleep(1) in main.c:
>>>> >>> http://grass.itc.it/pipermail/grass5/2004-September/015393.html
>>>> >>> and
>>>> >>> http://grass.itc.it/pipermail/grass5/2004-October/015746.html
>>>> >>> Moritz
>>> >> ______________________________
>>> >> School of Human, Evolution and Social Change
>>> >> USA
>>> >> voice: 480-965-6262; fax: 480-965-7671
>>> >> www: http://www.public.asu.edu/~cmbarton
> USA
------ End of Forwarded Message
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20041222/7de7c319/attachment.html
