[GRASS5] Re: [Gdal-dev] latest in the hdf-gdal-grass hdf-eos saga....
Andrey Kiselev dron at ak4719.spb.edu
Sun Feb 1 13:41:16 EST 2004
On Sat, Jan 31, 2004 at 11:31:40AM -0800, Jeff D. Hamann wrote:
> but after all that I still can't figure out how to make gdal-1.1.9.
> All I get when I type ./configure (without the --with-hdf4 stuff even)
> and make is:
> config.status: creating port/cpl_config.h
> $ make
> make: no target to make.
I'm agree with Alessandro, it is BSD make problem. Note, that makefile
in the GDAL root called GNUmakefile. That's why you can't handle it with
your make utility. Use gmake instead.
> So this project will have to go into the drawer again until I can some
> of th ese resolved... And after all that, does anyone actually if
> GRASS can import ASTER L1B images?
Yes.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
