[GRASS5] tcltk to default
John Gillette
JGillette at rfmd.com
Thu Feb 5 10:40:16 EST 2004
I'm sorry. I feel stupid.
Of course "grass53 -tcltk" works as desired.
Perhaps the help message should be changed as follows:
Usage:
Init.sh [-h | -help <... snip>
Flags:
-h or -help or --help print this help message
-text use text based interface and set as default
-tcltk or -gui use Tcl/Tk based graphical user interface
and set as default
[note: man page could be changed also. And grass5 needs to read grass53
in grass5.html page.]
Also, I suggest to add a section in the install file called
"RUNNING GRASS" after COMPILING MODULES ... and before THINGS TO DO.
(Technically running grass isn't part of installing but if you
are installing for the first time you may not be familiar with
the man pages yet.)
Copy help information there except change Init.sh to grass53.
For example:
STARTING GRASS
Ensure that the path to grass is in your PATH environment or
start grass with the full path name. To start grass:
grass53
Usage:
grass53 [-h | -help | --help] [-text | -tcltk | -gui] [[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
Flags:
and set as default
Again, I am embarrassed I could not figure this out myself.
John
