[GRASS5] Re: [GRASSLIST:2530] Re: v.in.ogr not building on Linux
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Feb 10 03:52:03 EST 2004
chris at fonnesbeck.org wrote:
> Forcing v.in.ogr to compile results in the following error:
> make: ***
> [/usr/src/grass57_exp_2003_12_06/dist.i686-pc-linux-gnu/etc/bin/cmd/v.in.ogr]
> Error 1
Thinking about it again I suppose also you would need to manually edit
include/config.h and uncomment the line
/* #define HAVE_OGR */
But it would be much better to find out what's causing the problem. I
thought perhaps something has changed recently to introduce a bug but I
didn't seem to be able to access the CVS server at Intevation yesterday
to check. Maybe Markus would know if anything has changed.
Paul
