[GRASS5] How to write to a vector coverage?
Cedric Shock cedricpublic at shockfamily.net
Fri Feb 20 19:54:29 EST 2004
To whomever may be of assistance,
I am working on a vector import method for Trimble .ssf files. I have
most of the file format worked out. Now I need to find a way to put the
information into grass. My target version is 5.3.
I took a look at the grass 5 programming manual, and did not find what
I'm looking for.
How can I open an existing vector coverage and add features to it. The
documentation indicates that we have a read only interface for existing
data and a write only interface for new data. How can we add new data to
an existing coverage? Can you provide an example of code that does this?
Alternatively, is there a high level file format that is easy to
generate with which I could use an existing import utility to bring the
data into grass?
I did not find structs for point, line, area, etc. How much information
can be encoded with vector information? I understand that we can do
diferent map layers, and can assign category numbers in those layers. So
we could have a database like:
Layer	Category
Roads
	1. US 95
	2. SW 48th st
Waterways
	1. Porcupine Creek
	2. Octopus River
Can we encode any of the following information with a vector:
Error / variance for points?
Elevation of points?
Other observations like regions with continous (non - categorical)
measurements like density associated with each region.
Can the vector implementation handle features which are single points of
data, or will I need to make site coverages for these?
Thank you in advance for your time and input,
Cedric Shock
