[GRASS5] Re: [GRASSLIST:2717] How to get topology of area edges
Hamish
hamish_nospam at yahoo.com
Thu Feb 26 02:03:04 EST 2004
> > > > I'm attempting to read GRASS's ascii vector output into a
> > > > graphics
> > > > display program that I'm writing... I produce this output (with
> > > > v.out.ascii) from a valid GRASS vector layer containing area
> > > > polygons. What appears in the resulting data file is a line that
> > > > denote an area and a number of points followed by these
> > > > points... i.e.
> > > > A 4
> > > > easting northing
> > > > easting northing
> > > note that should read
> > > A 4
> > > northing easting
> > > northing easting
> > > northing easting
> > > northing easting
> > > as long as the file format (and vectors in general) is changing
> > > for 5.7, is it too confusing to switch to x,y? maybe with an added
> > > header line"FORMAT: X,Y" or something? Now would be the time if we
> > > are ever going to fix that...
> > "FORMAT: X,Y" is good idea, but still could make much confusion,
> > there are many scripts working with ascii format.
> I agree about the creating confusion. BUT the existing way creates
> confusion too. Question is, which way causes LESS confusion and is
> easier to work on in the future?
> Will those 5.0 scripts not break & need updating to work with the new
> 5.7 ascii format anyway?
> > Maybe another directory?
> Moving things into the vector/ directory just cleaned things up, do we
> really want to go back and add more clutter?
[replying to myself..]
... maybe make an "ascii" file in the new vector/$MAPNAME/ directory for
the changed format. Putting new 5.7 data in dig_ascii/ seems wrong.
That should be reserved for old GRASS 5.0 files.. Otherwise we never get
away from the dig_* directory clutter even when 5.0 is history.
This would allow us to change the file format more drastically too: e.g.
do we really have to specify how many vertices will follow each feature?
L 341
y1 x1
y2 x2
y341 x341
is a pain to do; r.in.poly format is much easier to deal with for making
quick & simple custom import filters, as I do for Matlab->GRASS..
What about:
A 341
x1 y1 double_1a double_1b "label_1a" "label1b"
x2 y2 double_2a double_2b "label_2a" "label2b"
x341 y341 double_341a double_341b "label_341a" "label341b"
seems more logical to me than a huge att table at the end.....??
WEST EDGE: etc are also a pain to have to figure out. Couldn't we do this
in code? Or maybe that is useful for setting up new mapset regions..
maybe meta-data could move to "vector/$MAP/hist" too? Maybe not, self-
contained in one file can be good I guess.
just some ideas,
Hamish
