[GRASS5] Re: GRASS 5.3 with shared libs
Moritz Lennert
mlennert at club.worldonline.be
Wed Jan 7 11:49:37 EST 2004
Paul Kelly said:
> It is worth tidying it up though but I was under the impression that with
> the alternate build system we really should use a separate build
> directory (and that is how I tested it).
> Moritz: did you do it this way?
Yes, I create a grass_build directory and built in there. It worked
perfectly and instead of running a make clean fo some sorts, I just erased
the entire directory once I had installed GRASS.
Moritz
