[GRASS5] 5.3: shared libs and test in configure
Glynn Clements
glynn.clements at virgin.net
Fri Jan 9 13:37:38 EST 2004
Markus Neteler wrote:
> Here an example that the test
> if test "$SRCDIR" = "$DSTDIR" ; then
> { echo "configure: error: *** Build directory should not be the same as source \
> can fail:
> SRCDIR: /hardmnt/thuille1/ssi/cvsgrass_exp
> DSTDIR: /ssi0/ssi/neteler/cvsgrass_exp
> The situation is that I have changed into the source code
> /ssi0/ssi/neteler/cvsgrass_exp/ directory via soft-link:
> cd /ssi0/ssi/neteler/cvsgrass_exp/
> thuille:cvsgrass_exp[304.48] pwd
> thuille:cvsgrass_exp[305.49] /bin/pwd
Right. I appear to have been distracted by the fact that one of the
three cases uses $pwd (which will be set to "/bin/pwd"); however, the
other two just use "pwd" which will be the shell's built-in:
AC_PATH_PROG(pwd, pwd, pwd)
AC_MSG_CHECKING(for source directory)
if test -z "$srcdir" ; then
SRCDIR=`pwd`
else
SRCDIR=`(cd "$srcdir" ; $pwd)`
fi
AC_MSG_RESULT("$SRCDIR")
AC_MSG_CHECKING(for build directory)
DSTDIR=`pwd`
AC_MSG_RESULT("$DSTDIR")
For the $SRCDIR = $DSTDIR check to work correctly, we need to use $pwd
in all three cases. I'll fix this.
Glynn Clements <glynn.clements at virgin.net>
