[GRASS5] 5.3: shared libs and test in configure
Markus Neteler neteler at itc.it
Fri Jan 9 06:33:23 EST 2004
Here an example that the test
  if test "$SRCDIR" = "$DSTDIR" ; then
    { echo "configure: error: ***  Build directory should not be the same as source \
can fail:
SRCDIR: /hardmnt/thuille1/ssi/cvsgrass_exp
DSTDIR: /ssi0/ssi/neteler/cvsgrass_exp
The situation is that I have changed into the source code
/ssi0/ssi/neteler/cvsgrass_exp/ directory via soft-link:
cd /ssi0/ssi/neteler/cvsgrass_exp/
thuille:cvsgrass_exp[304.48] pwd
thuille:cvsgrass_exp[305.49] /bin/pwd
Personally I enjoy that it fails as I can launch 'make' as
usual :-)
Markus
