[GRASS5] Cygwin binary package
Mike Thomas mthomas at gil.com.au
Thu Jan 15 07:05:11 EST 2004
Hi there.
Whichever was the last version of Grass for which I sent a Cygwin binary
package, NVIZ was built into that package, tested and known to work.
Cheers
Mike Thomas
Glynn Clements wrote:
>Markus Neteler wrote:
>>>>>I have a report that one of the Cygwin binary packages on grass.itc.it
>>>>>includes a broken version of NVIZ (linked against Cygwin's tcl84.dll,
>>>>>which won't work).
>>>>>Can someone either remove the package, or at least remove NVIZ from
>>>>>it.
>>>>Is there much difference in having included a broken NVIZ instead
>>>>of no NVIZ?
>>>No NVIZ is easier to explain.
>>>The user reports that this was with wingrass_generic.
>He's changed his mind; apparently it was wingrass_xserver. That
>*should* be built with OpenGL and TclTk; however, you have to force it
>to use xtcltk and not Cygwin's Tcl/Tk, e.g. using
>--with-tcltk-includes=/usr/local/include --with-tcltk-libs=/usr/local/lib
>If you don't have xtcltk, then at least use --without-tcltk.
>It would be nice to have configure check that the version of Tcl/Tk
>which it finds will actually work, but I have no idea how to detect
>that.
