[GRASS5] Cygwin binary package
    Glynn Clements
    glynn.clements at virgin.net
    Wed Jan 14 17:48:16 EST 2004
Markus Neteler wrote:
> > > > I have a report that one of the Cygwin binary packages on grass.itc.it
> > > > includes a broken version of NVIZ (linked against Cygwin's tcl84.dll,
> > > > which won't work).
> > > > Can someone either remove the package, or at least remove NVIZ from
> > > > it.
> > > Is there much difference in having included a broken NVIZ instead
> > > of no NVIZ?
> > No NVIZ is easier to explain.
> > The user reports that this was with wingrass_generic.
He's changed his mind; apparently it was wingrass_xserver. That
*should* be built with OpenGL and TclTk; however, you have to force it
to use xtcltk and not Cygwin's Tcl/Tk, e.g. using
--with-tcltk-includes=/usr/local/include --with-tcltk-libs=/usr/local/lib
If you don't have xtcltk, then at least use --without-tcltk.
It would be nice to have configure check that the version of Tcl/Tk
which it finds will actually work, but I have no idea how to detect
that.
Glynn Clements <glynn.clements at virgin.net>
