[GRASS5] Cygwin binary package
Markus Neteler neteler at itc.it
Wed Jan 14 10:00:24 EST 2004
On Wed, Jan 14, 2004 at 10:47:42AM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > I have a report that one of the Cygwin binary packages on grass.itc.it
> > > includes a broken version of NVIZ (linked against Cygwin's tcl84.dll,
> > > which won't work).
> > > Can someone either remove the package, or at least remove NVIZ from
> > > it.
> > Is there much difference in having included a broken NVIZ instead
> > of no NVIZ?
> No NVIZ is easier to explain.
> The user reports that this was with wingrass_generic. Given that none
> of the OpenGL stuff (i.e. NVIZ & r3.showdspf.openGL) will work without
> an X server, wingrass_generic should probably be built using
> --without-opengl.
So some kind person should rebuild the package (using 5.0.3).
Then we replace the existing package.
Markus
