[GRASS5] cd $LOCATION revisited
    Markus Neteler
    neteler at itc.it
    Fri Jan 16 11:39:01 EST 2004
There is probably some confusion concerning $LOCATION variable:
Writing Helena (GRASS 5.3-CVS):
> > > if I work in GRASS on command line and I type
> > > GRASS:~ > cd $GISDBASE/$LOCATION_NAME/$MAPSET
> > > GRASS:~/grassdata/wake-spft/helena > pwd
> > > /home/helena/grassdata/wake-spft/helena
> > > GRASS:~/grassdata/wake-spft/helena > ls
> > > cats  cell  cellhd  cell_misc  colr  dig  dig_att  dig_cats  dig_plus
> > > fcell  g3dcell  hist  WIND
Answer Markus (GRASS 5.3-CVS):
> > On a standard version it doesn't work:
> > GRASS:// >
... confusing!
Clarification (desired behaviour?):
> I don't have any trick or modification - Jaro has explained it to me -
> when you start GRASS with tcltk interface the variables get set up and
> it works as written above.
> If you start with -text then I get what you have described
> as standard version. So far on the machines where I have tried it
> it works like this without any tricks
> Helena
For me it's strange if, depending how GRASS was started, $LOCATION
is set or not. Guess that this should be fixed.
Markus
