[GRASS5] can't start mon under WinGeneric but can under X11, again...
Jeff D. Hamann
jeff.hamann at forestinformatics.com
Wed Jan 21 15:59:46 EST 2004
I've run into this problem before, only slightly different. I
d.mon stop=x0
./configure --without-gd --without-odbc --without-fftw --without-postgres --
without-opengl --x-includes=/usr/X11R6/include --x-libraries=/usr/X11R6/lib
GRASS is now configured for i686-pc-cygwin
Source directory: /home/hamannj/grass/grass-5.0.3
Build directory: /home/hamannj/grass/grass-5.0.3
Installation directory: /usr/local/grass5
C compiler: gcc -g -O2
FORTRAN compiler: f77
NVIZ: no
X11 support: yes
DBM support: no
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: no
Tcl/Tk support: yes
PostgreSQL support: no
OpenGL(R) support: no
ODBC support: no
FFTW support: no
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: no
GLw support: no
NLS support: no
Readline support: no
and then make...
I then ran make install and tried to run grass 5.0.3. When I attempted to
start a graphics window, I got the following:
GRASS:~ > d.mon start=x0
No socket to connect to for monitor <x0>.
Problem selecting x0. Will try once more
GRASS:~ >
The graphics window works when I run from an X Window session, but I would
like to only run the generic build (not the X version, since this will be
run on a Windoze XP machine and having two window managers running is a bit
unsightly, but...)
Am I configuring the build correctly?
Thanks,
Jeff.
Jeff D. Hamann
Forest Informatics, Inc.
PO Box 1421
Corvallis, Oregon USA 97339-1421
(office) 541-754-1428
(cell) 541-740-5988
www.forestinformatics.com
