[GRASS5] grass 5.0.3 in debian
Glynn Clements
glynn.clements at virgin.net
Thu Jan 22 05:04:52 EST 2004
Hamish wrote:
> > > > the GRASS 5.0.3 package has been submitted to debian.
> > > A couple of points about the new Debian package..
> [I just installed it on a fresh machine]
> > > - after changing to tcl/tk 8.4, does NVIZ still work??? could
> > > someone check?
> > > > Build against tcl/tk 8.4 (Closes: #206844).
> > > for possible fix, see
> > > http://article.gmane.org/gmane.comp.gis.grass.devel/2036/
> > > maybe fixed in the latest tcl/tk packages?
> > To be verified.
> Nope, it doesn't work here.. same segfault.
> Putting -lpthreads in
> src.contrib/GMSL/NVIZ2.2/src/Gmakefile 's XTRA_LDFLAGS
> doesn't fix it anymore either. Maybe somewhere else?
> Compiling against Tcl/Tk 8.3 does work however.
Do you have both 8.3 and 8.4 on the same machine? If so, are you sure
that the headers, the link-time libraries and the run-time libraries
are all the same version?
FWIW, does Debian include the version number (e.g. libtk8.3.so) or
does it use libtk.so.0?
Glynn Clements <glynn.clements at virgin.net>
