[GRASS5] can't start mon under WinGeneric but can under X11, again...
Jeff D. Hamann
jeff.hamann at forestinformatics.com
Thu Jan 22 13:52:17 EST 2004
Glynn:
Thanks for the help. I tried you're suggestions to no avail.
When I built grass503 with the following configuration:
./configure --without-gd --without-odbc --without-fftw --without-postgres --
without-x --without-opengl --enable-w11
Could this be a cygwin problem, and if so how could I find out?
Jeff.
----- Original Message -----
From: "Glynn Clements" <glynn.clements at virgin.net>
To: "Jeff D. Hamann" <jeff.hamann at forestinformatics.com>
Cc: <grass5 at grass.itc.it>
Sent: Wednesday, January 21, 2004 7:38 PM
Subject: Re: [GRASS5] can't start mon under WinGeneric but can under X11,
again...
without-opengl --x-includes=/usr/X11R6/include --x-libraries=/usr/X11R6/lib
> > and then make...
> > I then ran make install and tried to run grass 5.0.3. When I attempted
to
> > start a graphics window, I got the following:
> > GRASS:~ > d.mon start=x0
> > No socket to connect to for monitor <x0>.
> > Problem selecting x0. Will try once more
> > GRASS:~ >
> > The graphics window works when I run from an X Window session, but I
would
> > like to only run the generic build (not the X version, since this will
be
> > run on a Windoze XP machine and having two window managers running is a
bit
> > unsightly, but...)
> > Am I configuring the build correctly?
> No; you need to use --enable-w11 for the "generic" version. And
> there's no point specifying --x-includes or --x-libraries in that
> case.
> AFAICT, you can install both the X11 and W11 ("generic") versions of
> XDRIVER (obviously, they can't both be called XDRIVER.exe, so one of
> them has to renamed), and modify etc/monitorcap, e.g.:
> x0:driver/XDRIVER:X-windows graphics display: \
> dev/fifo.1a dev/fifo.1b \
> ::any terminal
> x1:driver/XDRIVER:X-windows graphics display: \
> dev/fifo.2a dev/fifo.2b \
> ::any terminal
> [snip]
> w0:driver/WINDRIVER:Windows graphics display: \
> ::any terminal
> w1:driver/WINDRIVER:Windows graphics display: \
> ::any terminal
> and use e.g. "d.mon start=x0" or "d.mon start=w0" depending on which
> you want to use. This won't work with anything which has the x0/x1/...
> monitor names hardcoded (primarily tcltkgrass, but then tcltkgrass
> only works with X in any case).
> Glynn Clements <glynn.clements at virgin.net>
