[GRASS5] can't start mon under WinGeneric but can under X11, again...
Glynn Clements
glynn.clements at virgin.net
Thu Jan 22 21:25:54 EST 2004
Jeff D. Hamann wrote:
> Thanks for the help. I tried you're suggestions to no avail.
> When I built grass503 with the following configuration:
> ./configure --without-gd --without-odbc --without-fftw --without-postgres --
> without-x --without-opengl --enable-w11
With what result? No errors but no window?
Did you run "make clean" before/after re-running configure?
> Could this be a cygwin problem, and if so how could I find out?
Anything which works on Linux but not on Cygwin is likely to be a
Cygwin problem in some sense.
Were there any error messages in error.log? Does driver/XDRIVER.exe
actually exist?
Glynn Clements <glynn.clements at virgin.net>
