[GRASS5] problems with i.in.erdas in GRASS 5.3
Glynn Clements
glynn.clements at virgin.net
Fri Jan 23 23:06:10 EST 2004
Michael Barton wrote:
> I just tried use i.in.erdas to read in a multiband *.lan file of
> LandsatTM images. It didn't work and produced the error listed below.
> With i.in.erdas out of commission, there seems to be no way to get
> multiband images into GRASS. I tried r.in.gdal (I have 1.1.9 installed)
> and it wouldn't read *.lan images or geotiffs in multiband format. Any
> suggestions?
> I am using GRASS 5.3 (12 January 04 build) on a Mac OSX 10.2.8 system.
> The *.lan file is a version 7.4 format file of 7 Landsat TM bands, with
> a size of 375 Mb. Note below that it does recognize the file and read
> the header correctly.
> - - - i.in.erdas error - - -
> Swapping Enabled
> HEAD74
> pack type ------------- 0 == 8 bit/pixel
> number bands----------- 7
> number cols,rows------- 7768, 7225
> starting coordinate --- 1, 1
> map type (int, float) - 1
> number classes -------- 0
> unit-type: ------------ N (N=None A=Acre H=Hectare O=Other)
> area per pixel -------- 1.000000
> map coordinate -------- 67089.500000, 4414792.500000
> pixel size ------------ 28.500000, 28.500000
> UTM coordinates used remember that the UTM zone is unknown
> and must be set using the grass support function on the header file.
> WARNING: G_set_fp_type() can only be called with FCELL_TYPE or
> DCELL_TYPE
i.in.erdas doesn't like the map type field, and appears not to like
floating-point at all:
if(erdashd.maptyp == 0) /* integer data */
data_type = CELL_TYPE;
if(erdashd.maptyp == 99) { /* floating-point data */
data_type = FCELL_TYPE;
G_fatal_error("Floating point import doesn't work yet.");
As neither of these two conditions are met, data_type ends up as -1,
which isn't a valid map type.
Do you know how map type 1 differs from map type 0?
Glynn Clements <glynn.clements at virgin.net>
